Battery drain problem
Ditch rider
Problem just started this fall....98 Polaris 500 Classic that has E-start
Something is slowly draining the battery. Is there something on this sled that historically causes this type of problem?
How can I test the sled to find out where the drain is originating from? What type of tester is needed?
Thanks to everybody for your ideas!
First of all, are you sure that the battery is good? You would need a multimeter to test for a draw. Set it to the amps setting, unhook the negative side of the battery cable and put one of the meter wires to the negative battery post, and the other meter wire to the negative battery cable. Now the draw will be flowing through the meter so you can read the draw.
Meters usually have amps and milliamp settings. Amps usually go to 10 amps, so start there. If it is set on milliamps and you have too large of a draw, you can blow the internal fuse inside the meter.
How long does it take the battery to go dead, and how old is the battery?
We had to buy a brand new battery every stinkin year and we got sick of it, so we just left it in there and pull started it. Don't have any sleds with ES but buying batteries every year was a pain just so u could turn a key.
If you are buying a battery every year, you are doing something wrong... Ever try a Battery Tender?
haha, oh yeah, even took the batteries out for the summer, ran them one day a week on the slow charge, didn't do a thing. season came around still crap, so let it sit for 2 days on the fast charge, still nothing, junked it and bought a new one. Real men start their sleds with a rope :)
peter
[QUOTE=indy_500 Real men start their sleds with a rope
Thats funny go say that on totally yamaha
Ditch rider
Mike,
VERY helpful reply....thanks!
The battery is 3 years old. I remove it for the summer and put a trickle charger on it occasionally. It took less than a week for the battery to go from full charge to "not enough to engage the ES".
I do have a multimeter and will perform the test. I have to pull the battery today and charge it up first.
Any idea as to what might be causing it other than a wire rubbing through? Will a bad ignition switch cause the problem?
Thanks
DC
harvest1121
I thought I did not need electric start or reverse. That was when I had my 2005 Firecat. There is no way I would ever be without it now. Its nice just to hit a button to start and back out of the trailer. Wait till you start towing your POO dragging off the trailer is not fun. Well I guess you know how to be towed after all your problems last year lol Good luck this year
edmarino
To Ditch Rider
First off, a battery will loose charge if just left standing,you should keep it on a Battery tender when ever it is not in use, you can never over charge a battery with a battery tender. And yes a bad starter switch if shorted can and will drain the battery,quickly. If you let the voltage drop below 11 volts in a battery for a period of time it will sulfate then it is dead. A battery maintainer like a batteryminder plus model 12117 can sometimes rejuvinate a battery if not to badly sulfated. It is also a charger which can be left on indefinatly and will not hurt the battery. A good charger is cheaper then a replacement battery.
Ditch rider
Mike,
Thanks
DC
Mike,
I did not charge the battery first. Battery reads 12.00 volts on the tester, but when I turn the key to e-start it = nothing.
I removed the ground wire and tested per your instructions and the meter shows no drain at any setting.
I have an Innova model 3300 tester (see it @ iequus.com). Not fancy but it works.
doomsman
Note that 12 volts is less than 50 percent charged
is the water level right
are all connections clean and tight
is ground cable clean and tight?
i was never towed 500 went down in my yard, 700 went down right by a dealership so i left it there and came and picked it up, and my dad's 700 went down at a buddy's house.
Ditch rider
To Ditch Rider
I understand what you're saying but have been around sleds for a long time. Something changed/went bad here....
If the ignition switch is bad (you are referring to the key switch right?) then I would see a drain during the test I did at Polarismike's suggestion. Or are you referring to the starter solenoid which is down by the battery?
Not sure what to make of this = 2nd cell in the battery seems to be losing water...but I don't see a crack in the case anywhere, nor do I see water leaking out from anywhere.
Local auto parts store couldn't test the battery because the voltage was too low. Brought it back home to chage it and found the low cell as mentioned above.
I have the shop manual for this sled and I check the lighting coil output and it is good. There's a way to check the voltage regulator but I can't figure out exactly what to do.
edmarino
To Ditch Rider
If you have a short any where in your electrical system it would show on your meter. If you test across your + and - leads disconnected from the battery. You should have an open circuit if not the amount of ohms indicates the amount of short. If you have a short you will have to inspect each part of your electrical system to find it, i.e. starter, hand warmers, lights etc.
As far as the second cell being dry and no noticeable leak, then you could be boiling the water out when attempting to charge battery. Meaning this cell is shorted and not taking a charge also why the battery has no power. The battery should be able to hold 12.5 volts for at least 8 hours after you remove it from charger and let stand, if not you have a defective battery.
As far as checking the regulator, disconnect the battery and connect your meter across the leads and start your engine you should get a reading of 13 or more volts.
Ditch rider
To Ditch Rider
To test for a short you would put the multitester on DC Ohms?
I will start the sled tomorrow AM and check the regulator.
Ditchrider, if you have Zero volts when you turn the key switch, you either have a bad connection or the battery is junk. I never had much luck over 3 years with the lead acid snowmobile batteries. I have since switched to Odyssey battery, which is similiar to an Optima style, so we will see how long it lasts.
Batteries can show 12 volts, but the amps is important also. With that cell being low, it may be bad, which will affect output and may be your problem.
edmarino
To Ditch Rider
An ohm meter can be used on either a DC or an AC circuit, it is a way to check continuity or electrical flow thru a circuit. As Polarismike said a 3 year life on a battery if not kept on a battery tender all the time is about right. I keep mine on when ever the sled is not in use, meaning every day it is not being ridden. I now have five years on one and four on my other sled. That's because that's how old the sled's are. You can get a battery tender junior from Wing Stuff .com for like 24.99 with free shipping and no tax if you buy before Dec.14th. Most snowmobile dealers sell the same item for 39.99 or more.
fredster
I've had several sleds with e-start for the past 10 years and 3 years is what I get from lead-acid batteries....I've just gotten into the habit of replacing them at the 3 year mark. It is what it is........
L
lenny
you only get 4 downs and than the other team takes over, come on Indy, it's time, GO BLUE!!!!!!!! :D
