Best gas caddy?
rmk4ever
Looking @ the 25 gal ones. Anyone to stay away from? Would like one for both seasons, jet ski's & boat, & sleds.
snake
have had a plastic one for about 10 years,dont know brand,but works well. I think its either a tempo or moeller. one thing I did was put a pressure gauge and a valve stem in the tank. I put the stem in the filler cap and gauge in another cap on top. if you pressurize it with 5 psi=now you can pump uphill. works great if you have air nearby,like at my shop.it still gravity feeds the same
polaris4me
That's a great idea with the valve stem and pressure gauge. I have a 15 gal. Gravity feed seems to take forever to fill the sled.
snake
it works very well,just be aware that the more fuel in caddy=less air,so you have to put air in more often. mine sits outside my shop,with the air just inside door. I got sick of hanging onto a 5 gallon can, along with the spills.
One thing to remember, compressed air contains moisture. Not much, but its there and condenses to water.
rmk4ever
Excellent point, must be sure to have a "dryer" in-line. Currently looking @ 1 that has the hand pump to it, will also pull bad/old fuel from tank then just pump into plow truck.
likinit2
I bought one of the 110 gal aluminum tanks with an electric pump and an auto shut-off nozzle. Yes, it was a little pricey but it has turned out to be the best investment for my snowmobiling I have ever spent. If you want one that is portable I would use a 35 gallon drum and buy your pump accessories and strap it to a hand cart. http://www.jmesales.com/
