I recommend AMSOIL HD Diesel & Marine Engine Oil 15W-40 AME
The oil filter to use is an EAO25 although it has been discontinued by AMSOIL. AMSOIL says to use EAO59.
But I have lot of EAO25's in stock as I have 2 others customers with similar GM engine so I bought them by the case.
SAE 15W-40 Heavy-Duty Diesel and Marine Motor Oil
AMSOIL Synthetic Heavy Duty Diesel and Marine Motor Oil is recommended for diesel engines,
gasoline engines and other applications that require any of the following specifications:
- SAE 15W-40
- API CI-4+, CF, CF-2, SL
- ACEA A3/B3, E2, E3, E5, E7
- Global DHD-1
- JASO DH-1
- Mack EO-M, EO-N
- DDC Power Guard 93K214
- Caterpillar ECF-1A, ECF-2
- Cummins CES 20076, 20077, 20078
- Volvo VDS-2, VDS-3
- MB 228.1, 228.3, 229.1
- MAN 271, 3275
- MTU Type II
- Allison C-4
I have the filters in stock and SAE 15W-40 Heavy-Duty Diesel and Marine Motor Oil in quarts, gallons and 2.5 gallon size at my Hubbell shop. I will sell it you at Preferred Customer prices and no S&H charges when picked up.
What you could do is do oil analysis and use that to determine when to change the oil. I have prepaid oil test kits also.
