sweeperguy
Looking for opinions on break in oil, Syn vs. Dino. Reading older threads (13 and older) concensus seems to be dino for breakin then switch to full syn. Owners manual says gold for oil tank and pre-mix. ONLY INTERESTED IN SYN VS DINO, NOT POLARIS vs OTHER BRANDS. Last year with Austins sled dealer told him Blue for break in, then switch to Gold Also run it like you stole it? or per owners manual vary throttle, no WOT for first tank of gas. My Dad always said ride it new like you'll be riding it later.
Ok now one other question nagging me. I see posts saying that pre mixing oil in gas causes lean condition. Seems to me only worry of lean burn with a 2 stroke is that not enough oil to lube properly. Some cooling from fuel, but the volume of liquid is still there. just that it's pre-mix vs straight gas. If mixing oil in gas should have plenty to lube? So shouldn't have an issue with lean burn down? Pre-mix probably lower octane due to displacement of oil, so I'll set my fuel to Ethanol.
