I want to get a grill for our new camper. It is for on the outside of the camper like the one in the picture. I just Want some options other than the one from jayco. just wondering if you guys have see nanyhing else out there
i use a baby weber gas grill for the boat and at the slip is small enough to move where u need and it cooks like a full size weber
Looks cheaply built and you know it will be over priced if it is an option. Does the lid touch the paint on the side when raised? Mot sure if I would want open flames that close to a new trailer. Also what about grease splattering on your trailer? Table top model will do the job for safer, less expensive cooking.
It's not top of the line, but not to bad either. I've never had an issue with splatter. The lid does not touch the camper. The flames are under a sheild, so they are not really open. The unit sits in a metal frame that keeps it 6 inches or so from the camper.
When I bought my 1st RV I purchased the RVG and thought it was ok/convient. When I purchased my 2nd one, I kept the grill because the new one had mounting brackets on it. I do not recommend mounting it under your awning as smoke will find its way into your trailer. I would look for one that is mobile that you can rig up to your propane system with a quick connect. The red one from coleman is a popular choice.
