I don't think it is a good option if you intend to use if for any type of conventional trail riding. You certainly can brap, brap, brap, brap one down a trail and keep the motor togeather, but hold it at mid throttle for a 1/2 mile straight, and you will be installing a new top end at the least. In addition, you will not be fueling your sled throughout the day for the pump at gas stations. Your going to be mixing pump with race gas, or 100ll at a bare minimum. More than likely running at the least straight 100ll without significant timing, and compression modifications.
Positives:
-Ridiculous power
Negatives:
-Cost of the kit
-Cost of 100ll or race fuel. $5.25 per gallon for 100 LL currently. 110 Race gas can be had for just under $7.00 a gallon if your lucky
-increased tuning
-reduced reliability
-increased maintenance (reeds especially)
-working on anything under the hood takes that much longer, as there is many more components that are in the way of the stock components you will be needing to get at / inspect.
At the end of the day, your biggest obstacle is going to be riding style. These sleds are not suitable for long runs of consistent throttle position.
I know, not what you were hoping to hear.
With that being said, I am going to run one in the U.P. this winter, but I wont be running the Bill Nichols trail from Twin Lakes, up to Copper Harbor for lunch.
