michaeladams
the more chromium in the steel the better.18 percent chrome in the steel and you have surgical stainless. chromium aka chrome is what is added to iron to make stainless
bs, it can corode or pit won't rust.
Nice quote from Wiki, but read it all the way to the end.
Stainless steel can and does rust, but its rate of rusting is much less than that for low chromium alloys. Stainless steel must contain at least 12% chromium to be classified as truly stainless. Other metals are added to enhance more specific properties of the steel.Just a note for info, some of the best stainless steel will show signs of rust if it was in contact with mild steel before it was installed, at hammer marks, rust on the skin from when it was slid across a mild steel work bench and rust from being wire brushed with a normal steel wire brush.What makes stainless steel "stainless" is a chromium oxide passive layer. If this layer is damaged, be it as a result of the manufacturing process or some other means, the exposed metal is able to be attacked and your stainless steel will show signs of rust. The trick is to restore the passive layer as soon after manufacturing as possible, as well as limit the exposure of the material to iron contamination through the manufacturing cycle.Some years ago i worked for a company that built equipment for use on oil rigs. The main material used in construction was stainless steel. The most important thing to remember was that under no circumstance where tools used for works on stainless steel to be used for any other material. For example if a hacksaw blade had been used for cutting mild steel it was not allowed near the stainless steel. If it was used on stainless it was said to contaminate the material and cause a reaction in the stainless steel. even the slightest contact with ferrous metals could instigate rust. This applied to any tool, spanners, hammers any cutting tool even abrasive disks.As I understand it, there are at least two types of stainless steel -- ferritic and austentitic. Ferritic will rust in the right environment, especially if water is present.
LookinforSnow... may I ask who made the Chicken wagon? Look's like a great job; plenty of good eats for all!
