crossfire oil
sabercat
If by empty you mean there is some in there but not enough for another tank of gas, then sorry but thats about right.
no I get about 3 tanks to 1 tank of oil cats are notorious for coming out of the factory running verry fat on oil .do the math on your next fill.if running to fat pull lower belly pan un hook oil pomp arm and give 1 turn and run 1 more tank of gas and oil re check you should be good but I know of a few guys that had to go 3 turns.
