02edgehead
i recently put new bearings and a new track(used) in my sons polaris 600 edge x. at slow speeds( barely moving) you can feel/hear a jerking from the drive cogs actually slipping in the track. the track is plenty tight. the drive cogs are in good shape too. i have matching sled and my cogs are extremely worn and it doesnt do it. also when you are on and off throttle you can hear/feel it too. the gap between the lugs are the same. cant feel it when you go higher speeds but im sure its still happening. you can take secondary clutch and turn it quite a bit. as you do this i looked under and you can see drive shaft turning a bit between lugs in track. any suggestions.
