Just installed a break controller on my truck, and had all bearings, breaks serviced, and inspected for the season. Was pulling the trailer today for a short job, and noticed that when coming to a slow rolling stop, my front driver side tire would lock up, on loose gravel and pavement. The other was fine, and was not doing the same. I adjusted the controller to several different settings, but still had the same issue. Any thoughts on what the issue might be? Just to clarify, it doesn't lock up when applying the breaks in regular use, but if I were to turn into a driveway at rolling speed, or let off the break at a stoplight to let the truck creep forward,OR a few feet before stopping at a light, then apply the breaks, it occurs. I noticed some black break dust on the rim that was not there prior, and the hub felt a bit warmer that the other three. Thanks for any thoughts or ideas.
