L
lenny
I replaced the elements in my water heater. I looked in the hole of the bottom element and the tank was filled with deposits right up to the element. It's like calcium, the stuff is hard kinda like what builds up on the element itself after years of use. I figured I may just get a new heater all together but I figure I at least try an get some of that crap out. I bent a coat hanger with a little hook on the end and you would not believe what I pulled out. From looking close at this heater, I think the are designed intentionally not to last all that long. Why would there NOT be a large plug on the bottom of the tank to clean them out, the drain valve will not allow the crap in my tank to pass through, it just sits there and promotes corrosion on the elements. I got a pile out and I hope I can get a few more years out. even though the heaters are only $225, The inside tank lining is still clean, it deposits sitting on the bottom. maybe the elements are causing the buildup, water quality, maybe I should have it tested. who knows
