L
lenny
I have installed 4 can lights in a construction project and there is a 1" set back for combustibles to the can unit. I believe the unit has a sensor that will shut it off if it "overheats."
I should have spent a bit more money and bought a better can light fixture that I could insulate right up to. I insulated with celouse and buried the can and than cleared out around it for the set back. The insulation will not burn. I was wondering if i were to run only 65 watt bulbs would i have a problem with the fixture tripping. I don't like the idea of me loosing heat around. It probably sucks right up through the fixture more than we think, especially when the light is on and the heat it is producing cause a "draft like affect" drawing room heat out through itself.
What should I do? Yank those junks down and just use a ceiling mount light fixture or jump the sensor in the can and bury it will blown in. I cannot believe a 65 watt bulb could be a problem. I understand if i sell and the next bozo runs a 120watt bulb and sets the place ablaze. I like the look of cans but probably should not have used them. I'm gonna do a test tomorrow to see if they are drawing heat up through them buy seeing if smoke drafts up through them.
