Electronic Display "Bouncing" - '08 Polaris Switchback
mngolf4
The electronic display on my '08 Polaris is "bouncing" - meaning the speed value bounces up and down even when sitting still. I'm guessing a loose connector or bad ground or something along those lines. Posting for pointers before I spend too much time chasing the wrong thing. Thanks in advance JDers.
my buddies 04 arctic cat f6 does the same thing... he didnt think it was a problem... does it work okay when your riding it?
mngolf4
indy_500 - seemed to work (display speed) at higher speeds but if I recall correctly it "bounced" at lower speeds. It's never done this since I've owned the sled.
vx700xtc - I haven't started to troubleshoot yet, thought I'd post first and maybe someone has already troubleshot and fixed this problem.
I would suspect the speed sensor is shot. It not uncommon, it happens with a few (all mfg) & not an "expensive" fix.-Mezz
jeff_d
I had a 06 fusion that did the same thing, on the digital display it would jump from 0 up to 100+ mph when sitting still. It ended up being a bad speed sensor. Replaced it and all was good. I think it was only 60-70 bucks from the dealer.
coach
Wonder if it's related to the original problem:
2012 Polaris Switchback 800 Fuel display is inaccurate and will disappear completely when moving. Any suggestions?
