chords
Many times I have used a 5 Gal can to either pour or syphen using a long hose with no problems into a 28 Gal tank. Now, even knowing it will take many gallons to fill, after maybe 2 or 3 it fills up to the cap like its full. After a short ride I've checked again and its still visable near the cap.
I can go to the gas pump on the water and hold it full blast and it fills OK.
I have a couple ideas.
1) tank air vent clogged and pump pressure is enough to push the air out (there is no external vent so not sure where that is but imagine somewhere away from the engine ?)
2) maybe a screen in tank neck thats clogged, and again pump pressure is enough. (though I pushed a syphen hose down and hit nothing)
Any ideas or thoughts ??
