Firecat Anti-Freeze leak
Sno-Bandit Gary
Just got a call from friend riding the UP. Has an anti-freeze leak on his 05 firecat. Looks like it is coming from the back of the engine. Has anyone seen this problem before? Any advice?
Thanks
Gary
jimfsr
cooling hose probably rubbing against the frame, chaffed through. Pull the bottom pan and look around.
prob the hose they rout it right on the edge of the frame and it can wear a hole eave if it has the updated plastic cover over frame like a car door ding edge or windshield edge over frame.you can swap hose without pulling motor but it is a bitch
Sno-Bandit Gary
They called and found it to be the heat exchanger. Trying some JB weld for now and will see if it will hold up for the week until they get back.
