I'm sure some of you out there have some ideas.
A few years ago I left an older Honda 200SX ATV at my daughters to use. I'm sure it hasn't been run for at least a couple of years and when I was up there recently I found out that it won't turn over with the pull rope - most likely due to corrosion in the cylinder.
I've had pretty good luck unsticking 2 stroke snowmobile engines that have been sitting but I have no experience with 4 strokes. I didn't have time to mess with it so I just sprayed some Liquid Wrench in the cylinder to hopefully slow the deterioration.
I'd prefer to not have to tear it down. Should I pull off the recoil and try cranking it backwards with a wrench first (my usual trick)? It was running like a top when I dropped it off so I think the motor is fundamentally sound.
