Dooly's
If your sled came with dual carbides my advice stick with em, went from dual carbides to Bergstroms "Good but Ugly" single's, shims, ski savers, everything, terrible is all I can say, darting issues you wouldn't believe, everything the website said carbides were to eliminate did just the opposite on my sleds, Tightened the shock preload considerably "Sled was all over the trail" would come out of 1 rut then jump into another didn't want to go over 30 mph's wasn't safe. Loosened the spring preload all the way, was alittle better but wasn't safe over 40, tried loosening limiter strap, only adjustment was for a more aggressive ride, took out shims, no change, did some checking the ski toe in-out was toed in 1 inch when ski should be toed out 1/8 -3/8's of an inch, corrected that problem, now sled follows in my wifes rut "we have matching sleds" takes alot of effort to turn handelbars to get out of her rut, still zig zag's down the trail but not as bad as before. Our sledding friend has same sled as ours with dual carbides, no issues at all. Come to realize what he said is truth "because I changed from dual's to single's, gonna put shims back in and ride till season ends next year will have dual's back on. At one frustrated point I was thinking about putting the old carbides back on, they were wore done to nothing but would stop the darting as I didn't have this problem last year but I already threw them out.
