Grease Recommendations
for those of you using Mystik JT-6, would that be the low temp extreme in the blue bottle?
And could I use this on the ball on the hitch as well as the trunion bar ends too? Or would this be better?
dfattack, what I use is the Mystik JT 6 Semi-synthetic. A lighter blue grease in a light gold colored tube. The Mystik JT 6 low temp is fine, but JT 6 Synthetic Blend has much more application uses as it has a much higher max temp range.
eao
NLGI #1 is for cold climate. Friend uses this in the winter in his logging processors when temps drop below zero......
Arctic Synthetic Grease
This is what I use (sparingly) on trailer balls. Lot easier to carry around in truck for when needed. ►Synthetic Fifth-Wheel Grease
Site Sponsor
