Im thinking about putting some risers on my sled, not looking to spend much i have heard the 2 Inch PowerMadd risers are a pretty good deal, but. Any input would be great from you guys.
Thanks!
I would suggest standing on your sled in a riding position, holding your arms out at whatever angle you're comfortable with, and have someone measure the distance between your current handlebars and where your hands are. Depending on what kind of sled you have, you may need to move the bars forward which will require getting a swivel riser, which takes up about 2 inches.
I put a swivel riser and 4" riser on my 98 ZR, and didn't have to extend anything. I did have to reroute.
When you do it, make sure that your throttle cable has some slack at full left and full right turn. You don't want to have the throttle pulled when you turn!
Powermadd makes good stuff.
