The high beam switch goes bad on them causing that. or the regulator. Sometimes you can clean up the inside of the switch, & be good til' next time it buggers up. Usually the regulator will take out the lights all together.
Yeppers check all connections but if in stator will die no spark at all sooner or later. Sorry hope it is something simple but if stator you should know so don't get stranded.
