sean34590577
I'm changing the track on a 2005 edge chassis this weekend and was wondering if the experts could help me from start to finish please?? Also Happy Thanksgiving!! I'm thankful for the wise on here that help!!
Make sure it's jacked up high for starters. Start out by loosening the track tension all the way. Next, take out the 2 rear skid bolts located on the tunnel (down by your feet) after that, you can take out the front 2. Remove the skid. Next, drain the chaincase oil, remove pipe and can. You should have a drain plug under the chaincase under the belly pan. You can remove the exhaust as its draining. Next remove the chaincase cover, loosen the chain tensioner bolt all the way, remove the lower gear bolt (hopefully its not sheared). Next, remove the secondary clutch, and the speedo driveshaft housing located on the clutch side of the driveshaft. Now you have everything free and can finaggle the driveshaft out of there. When installing, if you need any torque specs, just let us know!
That's because when you do it a dozen times, it is!You make it sounds so easy!!! LOL!!!
