big10champ2003
Hello, quick question for you all.
I am trying not to spend a lot of money on rebuilding a clutch for a cheap indy 500 I have that I bought several yrs back and now just let friends ride or use as a emergency backup.
So my question is: It needs the clutch rebuilt. Stock weights are 49.5gram 10M5 weights. Would it be better to put 51.5 gram weights in or 47.5 gram weights in? I dont want to spend the $55 bucks on new weights if the others will work and I can get them for $20. I know the lighter ones will make the rpms go up, and the heavier one will lower the top rpm.... so which is the better route??? Its going on a stock set-up 1990 indy 500 with a L/C motor. I has a 133 track. Motor runs very good has 63xx miles and 135lbs comp. in both cyl.
Any thoughts would be greatly appr.
Thanks
Thanks
