Hey indy 500...
awbrennan
is this suspension and track longer
Does this have a longer than normal suspension and track. Is it possible to put a longer higher suspension on an Indy
jimfsr
This probably has the extra 10 or edge suspension. I can't really tell from the pix. Are you trying to get more travel, or just sit higher?
it has the edge and it is just what i need but i don't have $850 to throw for my backup sled. gotta fix the big block first! thanks for showin it to me though, i've been looking for something like that -something that was crashed- to fix mine. i just need an engine but would prefer a new chassis, if i were to get that i'd probably stitch up the belly pan put my front suspension, ski's, and track on it and go
awbrennan
I am wanting to have more travel and set higher. also is there a newer seat that will allow me not to have my legs bent so much that will fit on my Indy. or should I just customize my seat to fit my wants
unless you turn around and resell it, 850 sounds like a lot for just the suspension and seat. plus it's an indy 500 so it had the most basic shocks of that year but i'm sure they'd fit your needs as i wouldn't mind them
It has an engine. 3000 miles on it.
What sled are you riding now?
none... just need a new track on the 700 and weld the heat exchanger and she's good. the last sled i rode was last night and i feel bad, it was a cat lol. 01 zr 600 and it engages at 5,000 rpm, ski's pop up no matter how light u r on the throttle.
At least it ran AND you did not need a hill to get the skiis off the ground! HA HA HA
http://www.youtube.com/watch?v=imjk5_qPEkg
sorry, couldn't resist
hey the kitty has 4k on it my poo has 8k with no rebuilds on the clutch. plus 30 less hp. a while ago i could get the poo off the ground a little but nothing real big. not like i could catwalk with the cat but enough to get the ski's off the ground. oh yeah, i stood up on it last night too!
