High pitched whine more like a squeel
mebearman
1996 Polaris 500 Fan when I started it up it hade a High pitched whine more like a squeel that was relative to engine speed. It even had it when moving for a couple hundred feet then went away. Any ideas.
mebearman
I dont think it was the belt because i moved the belt around a little when it was running and noise never changed.
Don't know how you can move a clutch belt while running without losing fingers but if you say so....Then it is speedo cable don't worry will break soon there is a key in there as I remember that gets sheered off & squeels. Disconnect cable at engine take pieces parts out squeel will be gone but no speedo.
mebearman
It was running and I raised the belt guard and was moving the belt and could not feel or here any change to the noise. I am not sure about there being a belt for the fan.
