Hyperfax ; worth the price?
snake
anyone running it,and do you notice any difference like fuel mileage ? I know they say it melts at a much higher temp. but if it's not wearing are the clips going to wear more ? thanks in advance!!
I have them on the ice racer drag sled.thought they may improve time a tad.had lights set up tested with stock cat did the swap 30 min no change.cant say how long they last that sled gets maby 50mi a year 660ft at a time
I asked the same question a year ago & response then was NO not worth the cost for those that used them. Very few responses to you so thinking maybe even less people use them now. Lots of people said they chanage hyfax yearly ....just because so wanted to keep costs low. I'm a change the hyfax yearly just because guy so never tried hyperfax. Trend seems to be towards ice scratchers also get bene of better cooling & longer hyfax wear. Hope this helps.
big10champ2003
Ya Im a change the hyfax yearly kinda guy myself. They are cheap and its kinda one of those upkeep kinda costs, like buying oil, just only once a yr. Plus then you know you always have a good set on....at least at the start of the yr!
I had looked into those Hyperfax slides once, had heard that it did wonders on the xtra-12 polaris suspensions....but figured that if they were $100, I could put 4 sets of normal hyfax on for that.
reaper969x
plus if you change ur hyfax once a season you might notice other "problems" before they become real "problems" while ur down there
