I remove the engine from the sled to start. Got the recoil off. then the flywheel,this takes a puller to do. then the coil. I do not know what one is the pulser coil.
For anyone having to do this. Remove starter,motor mount, gas line, oil line and all the bolts going around the fly wheel cover except ones for water/oil pump. Pull cover and replace. wasn't as involved as it looked, took about 1 1/2 hrs
