favoritos
Harski
i found the same problem when we borrowed our friends inline and we were towing it with my excursion which is a one ton. When you get next to a semi u start swaying like crazy it makes me not want to buy an inline at all
when we were towing back and forth between illinois and the u.p. last summer our fuel mileage dropped by 1/10th of a gallon towing behind the excursion when we switched from our side by side to the inline both of which had the same load
Seems odd on the mileage. I know that you do need a longer trailer when going to the inline style. Maybe the added sidewall?
Our mileage does vary quite a lot based on driving conditions.
We did get a different inline midseason and it has a longer V and hitch. This trailer seems to pull much easier. We used to get vortex wind between the trailer and the back window on the burb. It would get annoying to listen to the window being sucked open partially in strong headwind driving. The longer hitch and v seem to have stopped that issue. It is also easier to get into the box of the pickup or back of the burb while the trailer is still hooked. We could not fully open the tailgate with the shorter hitch.
You can see the difference on the hitch length in these two pictures.
