jackshaft bearings... 1980 ac jag
rmk4ever
I had to replace the one behind the driven, so putting it back together now & when i put the driven clutch on I'm about 7/16ths to long. Don't know what happened but somethings wrong. Anybody got an idea? To long on jackshaft driven side.
lvr1000
Did you put the new bearing in the same way the old bearing was? In other words, is the extended race on the same side as it was before?
rmk4ever
Should be a spacer behind the top gear. That would pull it towards the chain case. Just a thought.
Hmmm, spacer you say huh? don't remember a spacer, but that would do it. When I put the secondary on, it (jackshaft) comes out to far. I have not lost any washers behind the secondary, could it be that the "floating" rotor on this just wont go back far enough on the shaft itself? & it is stopping the jackshaft from going to the mag side anymore?
rmk4ever
Did you hold the old and new bearing up next to each other?
Negative, old bearing come off in pieces via cut off wheel. I think I messed up the key way on the rotor? So now the shaft wont go far enough inside the chaincase. Little allen heads (that lock it to the shaft) are right on the bearing surface. Pretty sure it's a do over, kids are riding around the old reliable xlt now so they dont care. 10 inches here & still coming down. Hinckley MN.
