ok i got 2001 600 xcsp just put hot seat twins on going to a stock can with stock air box was told to run 430s from 0 to 25 degrees and put 450s in from 0 to -25 this sound rite? plz ne help would be appreciated thnaks
Ok if u think that is a little lean what do you think would be a little richer or would be ok to run? Maybe put 450s in and if it gets a little colder go a litle bigger? I appreciate the help
so there were 410 in my sled when i opend it up? so if its between 0 and 25 i should run 450s???? and if its colder 0 to negitive 25 i should run 430s or 440s? thanks i would like to get this figured out b4 i go up north and blow n****y lol well i hope one of you guys help me
450+ in warmer weatherso there were 410 in my sled when i opend it up? so if its between 0 and 25 i should run 450s???? and if its colder 0 to negitive 25 i should run 430s or 440s? thanks i would like to get this figured out b4 i go up north and blow n****y lol well i hope one of you guys help me
470+ in colder weather
Read the plugs and piston wash, and make your own determination after that.
430's are stock and they are fat from the factory. I think 450 is gonna be too much. Personnaly I would start with the 430's. Again...the plugs/piston wash will tell you the story. Main jets are mainly for WOT. If your a little lean you won't burn down testing. Hold it wot for a couple hundred yards and check plugs. If too lean fatten them accordingly.
