Anyone seen this movie? What a concept!
I used I think 1 3/4 steel about 10ft long so it would span 5 joists and if I needed to pull something verry heavy like a boat motor I could pull under and wedge some 4x4 under each side still have not had to pick up anything that heavy but the option is there
i don't think it's a good idea to hang on a pipe fitting
The shear strenght of those threads has to be in the thousands of pounds . Do you know other-wise ? I was just guessing from my strenght of material class years ago. I thought about using a solid piece of 0-1 or S-7 for the cross shaft and cutting the threads on it. I just don't get carried away lifting too much. Just the ends of sleds or jet-ski's. The hoist only has a 880# limit. I would appreciate if you have other info. I estimated the thread shear strength to exceed the hoist limit ???? Please say so if there is something I didn't factor in. You have me worried.
Mike
