Thanks guys!
Over time, most of the material that was glued to the inside of these hoods for sound deadening and/or insulation crumbled and fell off. Not so with the glue. I swear this stuff could survive a nuclear blast.
Removing the glue isn’t nearly as exciting as it sounds: try to soften up an area with lacquer thinner, scrape it with a razor blade, sand it, and repeat the cycle many times to rid all of the hood of the stuff.
Once the glue is finally gone, some finish sanding to get the hood ready for paint.
As is often the case for any painting project, 90% of the time is prep and 10% is the actual painting. That 10% is my favorite part.
