Kawa-Bunga! A Project Sled for 27
Looks like that set-up would really cut back on engine vibration through the chassis. Very interesting set up. Personally I always liked the Kawasaki invaders. Ran good for back in there day. I remember the next door neighbor to my grandparents had a couple of Invaders while I was on a Johnson rotary and a scorpion stinger 3. I was trying to talk my grandparents into getting one but that didn't go anywhere.😜
I think you might make a good point here. This sled has a smooth feel to it and some of that may be due to improved vibration dampening.
I haven’t run into anyone that owned an Invader or knew someone that had one that doesn’t say these were very fast for the time-period. The Intruders are not in the invader’s league but they’re no slouch either. When you get on the throttle and that motor starts pulling from all three carb jets, it’s still fun (that’s right, the carbs on the Intruders used a third jet, in addition to the pilot and main).
Rear suspension is removed and even though all the chassis bolts/nuts I've encountered are SAE, the suspension mount bolts are metric. Strange.
Yes, I guess Mikuni called them “Powerjet” carbs but Kawasaki used the term “Econojet”. As I understand it, the goal was to improve mileage while maintaining performance.
The main and pilot jets operate as they normally do on Mikuni’s. The third jet (aka econojet) is a somewhat different type jet and is located in the bowl. This jet feeds fuel directly into the carb venturi via a line from the bowl. The rate of fuel delivered through this jet is determined by the air flow through the carb.
According to Kawasaki, this jet only comes into play over ½ throttle and is most effective at wide open throttle. I’m not sure where the economy aspect comes in but maybe it’s below ½ throttle because it allows for a smaller main jet, which usually comes into play earlier at about ¼ throttle. The smaller main can be seen in the specs, which are as follows:
LH cylinder: pilot – 25, econojet – 130, main – 140
RH cylinder: pilot – 25, econojet – 120, main – 140
This is a concept that I had never heard of before I bought this sled.
On a somewhat humorous note, Kawasaki doesn’t call the choke a choke. They call it a “Enrichener Circuit.” Very impressive sounding.
Technically.... a plunger type choke set up is more of an enrichener more so than a choke because you are not "choking off" the air supply to privide a fuel charge required for starting, where as an enrichener is only providing an "enriched" fuel charge for starting, so in retrospect...Kawasaki had it right LOL! "3rd" jet sounds more like and attempt to help with midrange slump round slides were notorious for, better fuel economy as result of not having to lay into throttle as hard to get past it in a 2 jet system?
In today’s world they might have called it “Viagra Circuit” 😂
Conversely, companies could be marketing “Enrichener Pills.” Sounds so much better.
Yeah, you’re technically right Brian. The plunger setup is a whole different deal. I also thought the same about mid-range but what’s curious is that it feels to me like the sled is a little flat in the mid-range. My friend who also has an Intruder has made the same comment.
Now it could be that the carbs on both our sleds need maintenance. I have cleaned the jets on mine but have not boiled the carbs and he has done neither. It’s probably not a factor but the throttle pull on mine is way out of adjustment so it’s hard to even get a feel for where half-throttle is. We'll see how it runs when everything is refreshed and properly adjusted.
BTW, sold the 250 TX today, about 2 hours after posting it. People love that sled. Hate to see it go but it provides an injection of cash that I'll be using to begin ordering parts.
This installment is a l little longer than usual but I thought it necessary to give everyone a good idea of what goes on in the shop some days.
The task for the other night was driveshaft/track removal. The first step seemed simple enough: remove the chain and gears but between a generous amount of factory Loctite and about 80 lbs. of torque, I could see that the lower gear bolt wasn’t going to budge without an impact wrench. There wasn’t enough room to get straight-in access with the impact wrench so I cut out a “small” section of pan to allow access. Problem solved. And you thought I was a patient man.
Kawasaki took a little different approach to the speedometer drive assembly. Rather than mount the drive on the clutch side, which was common, they mounted it in the chaincase cover. On the other end of the shaft was just a bearing and bearing housing.
Problem was, the bearing on the clutch side of the shaft was pressed on the shaft and the housing was pressed on the bearing. Even though the shaft allowed some lateral movement there didn’t seem to be any way to get any kind of leverage to remove either the bearing or the housing with the shaft still in the sled. Prying, pounding and a puller were out of the question.
After some hard thinking, I came up with a solution. I figured that since there was some ability to move the shaft, I could shim the housing against the tunnel so the shaft was recessed in the chaincase by the thickness of the shim. I thought 5/8” plywood would do the trick.
On the chaincase side, I found a socket that matched the bearing center diameter, a longer shaft bolt, and some washers. The idea was to thread the bolt into the driveshaft, tighten it against the socket, chaincase bearing, and chaincase to pull the driveshaft towards the chaincase, thereby either pulling the shaft out of the bearing on the other end or the bearing out of the housing. I didn’t care which.
I thought it moved a little on the first torque-up with a rachet so I backed it off and added a couple more washers. On the second try, pow! The bearing let loose from the housing. Once the housing was off on the clutch side, there was plenty of room to fit the bearing through the hole in the tunnel and the shaft and the track came out in about 3 minutes.
Kelly, just a tip and for others, some of you may know this and some may not, for bolts that are torqued and suspect there is also loc-tite and there is no real good way to get heat in there or may be in sensitive area where you dont want direct heat applied. A high Wattage soldering iron works best.... take the soldering iron, place it on the head of bolt/machine screw, allow soldering iron to heat the bolt and melt the loct-ite for easy removal without having to heat everything around it, higher wattage soldering iron's will heat bolt faster
Nice explanation & pretty darn clever. Reverse engineering is a science of its own. You continue to impress. Now, what are your plans for the pan section you removed?
The soldering iron is a great idea. I’ve been having issues on one of the Cyclones with rear track idler bolts loosening up. I wanted to use Loctite but was worried about having trouble getting them loose if I ever needed to adjust the track. The soldering iron technique would make this easier. Thanks for the suggestion!
Room for the turbo
Or at least a set of pipes. No, this pan is destined for the dump. It has a long crack right smack in the middle from a direct hit by something. It was reinforced with a sheet of aluminum but I have two other pans that, while they have unique issues of their own, are better than the one on the sled.
After a bit of time away from the shop, back in action....
With the track removed, next up was the removal of the chaincase and jackshaft and this is probably a good spot for a little background on the jackshaft situation.
In January, when I was going over things on the sled, I discovered I could move the secondary up and down about an eighth of an inch. Pulling the secondary revealed the ugly truth. The bearing was so shot it had pieces broken out of it.
I knew better but I hoped that the play came from bearing wear and not shaft wear. Nope, the constant hammering had worn the shaft badly.
Now this is where “dumb luck” came in. What are the odds that someone has a 46-year-old snowmobile jackshaft for sale? Against the odds, a guy had one for sale on ebay that, other than a little surface rust, seemed to be in decent shape. After cleaning and painting, it looked like new and went back in the sled.
This will save a lot of time when things start going back together. The shaft can be reinstalled on the chassis with the new clutch side bearing still mounted in the housing. Easy.
So now we’re down to an almost-bare, grimy chassis.
"What are the Odds" indeed. This is one of the things that separates you from the rest of us. Finding an obscure part from 50 years ago and giving it New Life! I'm guessing the UPS Driver must be a regular visitor around your place. 📦🚚
P.S. Your wife is wondering why all the good towels end up out in your shop?​
Although I do miss the ease of being able to work on those older sleds I do not miss all the grease and grime that seemed to infiltrate every nook and cranny of the engine compartment and was as difficult to wash off as well used diesel oil LOL!!
" P.S. Your wife is wondering why all the good towels end up out in your shop?" LOL!!! TOO FUNNY!!!
Luckily, my wife is a towel freak and is constantly replacing perfectly good towels, to my benefit.
You almost have to wonder where all the grime comes from. You often hear the expression “greasy triples” because they are apparently notorious for creating grime.
Once the pan was off, things looked a little cleaner.
Speaking of pans, as I mentioned, this one had taken a good hit and had been reinforced with a sheet of aluminum. I think they used enough rivets.
