Long Haul Trailer Questions?
I'm planning on driving my Ranger Boat on Ranger trailer to FL from WI using my 2004 Avalanche about 3400 miles RT. The trailer has oil bath lubrication & electric brakes & probably about 2200lbs with boat packed & good to go. Any trailer maintenance I need to be aware of along the way? Any trailer laws or speed laws on the Interstates in WI, IL, KY,TN, GA & FL that I need to know?
Thanks,
Whitedust
and the spare hub not ez to find the oil bath hubs in the metro let alone in a town of 400 300 mi from any real town.better to have and not need.have fun fishing the backwater my fav kind casting among the mangroves until you catch a big snake that is
phazerpilot
been about 15 yrs since i've done it, took a tracker bass boat to the keys. speed limit was the only restriction i can remember. the hills in tenn. are not to bad especially if you have driven 45 to twin lakes in a snow storm
snow_monkey
Thanks,
Whitedust
Lube your ball, check tires for dry rot, inspect bearings,spare tire, See ya!
Real good idea about spare hub. Also correct in the mangroves if I don't recognise it .....it never gets in the dang boat! Lots of wierd stuff in that warm water NOT like fishing in WI in any way other than it is wet.lol ;)
and I dont think I have ever used shrimp for bait in WI hmm maby I should give it a try.it is crazy how hard a salt water fish can fight new guys think they have Jaws till a fish the size of a large perch comes up.do you have underwater light that is way cool at night if calm head out in the gulf a bit and watch some sharks then catch some.Ranger real calm.my cuz and me were fishing in sm kayaks about 15 yrs ago when he hooked what I am sure was a big shark it took off for open water.was pullung him so fast he was making a wake and the nose was bouncing up and down till he cut the line wish we had a cam on that one.
Maybe use shrimp in Mississippi River North you might catch a channel cat maybe not? Naw I would probably just eat it myself no use wasting good bait shrimp.lol
700classic
When I make pitstops, I usually walk back and put my hand on the hubs just to make sure they aren't too warm. Can catch a problem early sometimes that way.
mikeh906
You really should be fine, with a trailer I try not to run to fast, but want to get there. Yep, check the heat. Made the trip 1x with two trailers from Calumet MI. 1887 miles one way. The pot holes on the way are brutal to say the least. We got stuck in a small town in TN looking for a sled trailer tire as not alot of sled trailer needs there, had 2 spares for each, both were loaded to the gills. 100 miles or 3400 miles bring what you need x2. The boat trailer needed nothing along the way, but I had bearing buddys and shot some amsoil grease into the zerks while we had down time. I had extra everything with, spares, bulbs, hubs, bearings wiring, valve stems, ect. but I was moving so had anything I needed with to deal with problems, even plugged in the air compreser at 9:30 pm to lift and remove tire, changed it on the motorhome carpet. Get a tow policy, make the call. What you fishing for?
Stealthy1
No need for a spare hub if you have done proper maintenance! I have done this trip twice a year, down and back for almost 10 years and never took a spare hub. Bearings fail for a couple of reasons, lack of grease caused from bad seals, rust from water intrusion, or improper adjustment. Check the back of the hub to insure no grease splatter(bad seals}, jack up a wheel, spin to make sure it is smooth and silent, i.e. no grinding noise! Grab the wheel and check for excessive freeplay. If you have to ask what excessive freeplay is take it to a mechanic! Oil bath hubs are very dependable, as long as the seal has not been compromised. If the oil looks milky you have a problem with the seals and they need service.
I39 through IL is now 65 mph pulling a trailer, the toll road is still 55mph. By taking I39 you bypass Chicago, Indy and Louieville, but get to drive about 50 miles further, the fifty miles is worth it!
What you do when you get to FL and before you leave is important. Before getting the hubs wet, make sure the hubs are cooled down from the long trip. Don't launch the boat until this is done. The warm hubs hitting the cooler water will cause water to get sucked in through the seals otherwise. Before you leave, check the sight hole on the hubs to make sure the oil is not milky. Grease any zerk fittings on the steering tube , and lower unit on the motor before leaving, also run the tilt and trim up and down a couple of times after lubing and then lube again, will push any salt water out! Don't forget to check your air pressure on tires also.
I check hubs after about 50-70 miles for heat, if they aren't hot by then you will be good to go for the rest of the trip. I check them when filling up with gas after that.
3400 miles round trip, fishing Mangroves...sounds like you are going to the west coast, probably between Venice and Ft Myers? Englewood? If so, some great fishing and boating, have fun!!!! Nothing better then fishing salt water.
dfattack
I'm sure your hubs are like mine (I have a ranger trailer too). If they start to turn brown they need to be serviced. Wouldn't hurt to have them checked if it's been a while. If you haven't had the tires balanced in a while that would be a good idea too.
Have a jack that can actually raise the trailer enough to change the tire if necessary along with the correct sockets, breaker bar and torque wrench to install the spare. Know how much to torque the lug nuts if you have to change the tire.
If you can, don't put the cover on the boat. Ranger doesn't recommend covering the boat unless weather is bad. The cover will still rub along the fiberglass even if it's installed correctly. This is actually the first thing the sales rep told me when I picked up my boat.
I'm pretty sure you have surge brakes by the way.
Have a motor toter. I don't trailer without it...ever.
mikeh906
I reread your post, a few questions. Are you running in fresh water? If not, why would you even think of dipping it in salt? What and where are you fishing for? Lots of great fresh water fishing down here. Lots of great salt water fishing here also. But I can not think of putting my freshwater boat into the salt water, its the kiss of death to the boat. Make sure your jack fits under the trailer with a blown out rim., yet high enough to lift.
lvr1000
touch tire then hub. i have blistered my hand. brake pad came loose and wedged under the other. i carry spare everthing.
balance tires!!
woodi
whitedust Do u have the new style trailer with 5 wires and it works like surge brakes? That new oil in the axles was a great idea wish I had that on my boat trailer. The guy I bought my boat from fished the walley circuit all over the country & brobally put on about 12,000 miles a year pulling the boat with his 2005 avalanche. I know Indiana use 2 have a speed limit on trailers but I don't think any of the ones u mentioned had any special regulations. Hate 2 say this but I'm ready 2 get out after some walleyes.
bgruschy
If it's a tandem trailer, I'd take 2 spares, I've blown 2 at one time on my cobalt trailer, not much fun, make sure you have the correct wrench to change a tire, I know that is pretty obvious, but often overlooked. I'd also carry a roll of gorrilla tape. My brother blew both tires on his ranger trail and it pretty well took out the fiberglass fender, lots of gorrilla tape to hold it together until we got to real tools. good luck with the fishing, I was just watching in fisherman this morning, they were using gulp shrimp catching big redfish in somwhere in the gulf.
