I am looking for a descent 2006 to 2009 4stroker and have come across a few sleds with only a few hundred miles on them example 2006 apex with 856 miles are these most likely salvaged sleds or are they for real and how can you tell?
I have purchase a good share of used equipment. I pay very little attention to the odometer....the fact that they can be replaced or disconnected very easily means they aren't much of a guage of use.
Look at the engine compartment, skis/wearbars, track, bumps and bruises, spare parts, THEN compare to the odometer. Sloppy steering is another indicater.
Newer sleds should have fewer miles, but older sleds will rack them up unless they didn't get used much and then you have cracked fuel lines and gummed up gas tanks....they should be completely gone thru before you trust them out in the extreme weather.
I used to laugh when I saw sleds with 28 miles on them...two years old. If YOU bought a new sled how long would it take YOU to put 28 miles on it????
And that's why you can't trust odometers....
Was riding with a friend who totalled his sled. The next day he went out and bought a new sled (same brand). Before heading out to ride first thing he did was swap out the digital speedo.
Took more time to open and close the hood then to switch them.
Just another example.
I have a friend of a friend of a friend who hooks speedos up on a bench and hooks a dremel variable speed up and runs the miles off in reverse at about 60 mph to not burn up gauge. Iit takes a couple days to remove any sizable mileage. Speedos are also on ebay all day long to buy for just such purpose.
Why would you put a speedo with miles on it in a new sled?" New sled should be close to zero miles????????
Lots of clean USED sleds out there no need to purchase new.Used is the ony sleds some can afford.
Turning back speedos,cracked tunnels makes it sounds like a bunch of crooks out there selling used sleds. Are things really that bad or most very honest people just selling sleds in as is condition?
Another reason to purchase new. As clean as I keep my sleds I have friends constantly egging me on to roll her back. This is just not my style but I would not doubt if someone rolled back my old edge. It could of passed for a sled with under 2,000 miles and had over 7,000. Someone gets a bad deal! There was a thread where a fellow snowmobiler found a friends sled for sale with less miles than traded in, buyers beware!
