So I was out in the garage yesterday and I hear the wife yelling, I run inside to find the toilet over flowing. I quickly turn off the shut off valve to the toilet and start throwing down towels. Long story short I walk down stairs and I hear drip, drip, drip. O great water is dripping down through the subfloor. I cut a hole in the bottom of our bathroom vanity (wouldn’t you know it there was a floor joyce directly below the vanity) and I remove a small section of sub floor below the vanity. There did not appear to be a lot of water that got in there but some. I got a fan in there to start drying things out as quickly as possible. I walk down stairs a little while after and you could see where the water fallowed the sheet rock seam (on the celling). So I turned on the fire place and directed a fan towards the wet area. This morning everything is dry on the surface but I am sure it is still a little damp in there.
The question I have is how can I touch up the basement celling (this morning a light shade of yellow about 3’ long ½”-1” wide in spots). I don’t think paint is a great idea as I am guessing the new paint will be “whiter” then the current. Bleach, some other way?
On a side note to all…..walk your wife and kids around the house and show them the shut off valves to the toilets, sinks and the main water shut off in the basement, as you never know when you won’t be around!
