Need Help Fast compression
I'm looking at getting a sled mxz 600 2001 I have not done a compression check but the guy did 125 in each cylinder is this low or about on? Please help!
thanks,
Tim
It truly depends on the tester. Make sure the sled is warmed up before the test (cold test always gives slightly higher #'s). I would not buy it if it's lower than 110. Most important is that the cylinders are within a few #'s of each other. 5 PSI apart is pushing it.
snowbuff
A fresh 600 doo is about 135#. Like Indy said, it depends on the tester, make sure the motor is at temp. Don't forget to hold throttle wide open. 125 will be fine as long as they're both the same. If miles are high, you might want to freshen it up anyway.
