I discovered a condition with my 5 yr old home today that I'd like to understand from framers or builders as to whether it's a "normal" condition, or something that should have been remedied at construction.
As mentioned above, I purchased my home new 5 yrs ago from a local builder. The home had a warranty that is now expired, but I've discovered a condition that does not seem normal to me and I'd like to call the builder to resolve but need advice.
The past two winters we've noticed a mouse problem in our unfinished basement, but nothing in the upper two levels, main floor and second floor. So today, I set out to try and find out how they were getting in and thought I could seal the area...assumed it was a gap around a vent, pipe, etc. But what I found was even more startling.
I discovered that (forgive my terms, I'm not a builder but hope you understand what I mean) my subfloor platform on at least two sides of the home extends by 1-2 inches beyond the sill plate (from the exterior of the home you can actually extend your fingers up and under the siding and sheathing, into this gap and into the interior of the basement). I pulled the insulation back that was placed between the floor joists and on the top of the foundation in the basement and light comes flooding into the area between the joists. In both cases which I discovered (and i did not search the entire perimeter) this occurs in a corner...I assume the subfloor platform was extended over in an effort to square the corner. But if this were the case, should the sill plate not have extended out as well?
Is this something that would be considered a building defect vs. a warranty item and perhaps something I can hold the builder, even 5 years later, responsible to remedy.
In either way, what is the best way to remedy the issue? I began to spray the can foam insulation in several of the areas, but quickly realized the gaps in some cases were too large and in some areas I couldn't get the can and nozel to fit.
All advice/suggestions are welcome!
Thanks
Thanks
