New sled - quick question
elf
Finally pulled the trigger on a new sled. Picking up a 2010 600 RMK 144" tomorrow and taking it west on Friday.
So my question is I need to get a spare belt. I was looking online and see the belt for this thing is over $175. I also see the 600 IQ and Switchback run a belt with the same center to center dimension for about $100. Could I get one of those for a spare instead?
mjkaliszak
I have to buy those big $$$ Polaris belts for 1 of my sleds. Mine is $189, don't like the price BUT we are not blowing them up either . My experience has been over the years that the sled manu's are pretty close to getting the belt application right. Any time I had tried an aftermarket or a lesser belt , ( ON TRAIL sleds ) I end up picking the pieces out of the bellypan.
my .02
zimmbob
The cheaper belt will not last as long, and in the mountains, you are going to be harder on the belt than on a trail. spend the money, you'll be happier in the end.
M
mrskidoobydoobydoo
heres a thought dont pull the trigger your going to regret it... how are you going to break it in if you go out west right away...
zimmbob
I've never had a dealer tell me I need to "break in" a belt. Not saying it isn't what's needed. But my experience is that I've never "broke in" a belt, and I've had fabulous luck with belts for the 15 years I've been riding. Not one time has a belt gone bad early on me, that I couldn't contribute to my own stupidity (ie. lock the track on a stupid little tree, put the wrong size aftermarket belt on....)
Sometimes, I just think things are over technosized (I made up that word). You buy a spare belt, do you really go 'break it in' then switch it to save it for the spare? No, I don't think so. It sits in the storage area until you need it. Then you ride like you want to ride...
JMHO....
latner
JMHO....
ditto
elf
As far as breaking in the belt, I agree, you don't do anything for that. As far as breaking in the sled, I hope to get 50-60 miles on it before I head out west with it. It should be fine by that point. I debated whether I take my 06 with 6000 miles out there or the new one. And the fact the new one is under warranty wins for me. I mentioned to the dealer that I was concerned and he said he's been out there 3 times this year so far with 3 different sleds and the most miles on any of the 3 was 10 when he went out there. Just vary the throttle for the first tank of gas or so and it should be good.
oldguy
Elf, I ran into the same problem when I went to get a spare belt for one of my Polaris sleds. The difference I could see was the expensive belt had taller ribs on the top. I brought the cheaper one and use it for a lifetime spare. If you blow the expensive belt it came with, run the cheaper belt until the next available dealer and then shell out the dough to buy the expensive version. Who knows you maybe able to run the original belt for years.
Good luck with your new purchase, and thanks for doing your part to keep that northern MN economy thriving.
srt20
the expensive belt is an 1115 belt. It should last a very long time assuming the clutches are aligned. The cheaper belt is a 1122 and is also a very good belt. It will not last as long but should last longer than most belts did 5 years ago. An even cheaper belt is a 1080. While the dimensions are slightly different, it will work, and lots of people only use this belt. The 1080 belt will give you the best performance because it is a softer belt and grips harder. 1122 a little less, and the 1115 is the hardest, but will last the longest.
I use a 1115 as a main and a spare. But my sled is a 700 and has clutch work among other things. My sled puts alot of power to the ground, and I ride hard. So I feel the need for the strongest belt. Having said that, I also have over 3900 miles on the current belt, and no plans of changing it out.
I wouldnt have any problem putting a 1080 belt on a stock 600 trail sled. I have never ridden in the mountains or really deep fluff, but I imagine it would be harder on the belt. Alot of out west guys use extra venting to keep their belts cool. Heat is the main enemy of the belts.
I think I would just get the 1115, if your gonna be out west, and be done with it. You really dont know if the clutches are aligned right. None of the brands have very good tolerances when it comes to this. Hope this helps.
P.S. I always break in my belts, which includes washing them with soap and water, and running them fairly easy till the belt builds up some good heat. No WOT, and No barely using the throttle to get the sled moving. To easy of throttle slips the belt to much and is just as harmful as slapping on a belt and nailin it.
LOL. Dealers pushing belts again. get the 1180 or std. belt. I do not buy the 1115 belt. It is written sucker all over it. I have a 755RMK 151x15x2 , I run the same belt as my switchy. I run the 1180 belt all day, every day, Even out west on my 05 Switch with 144x15x2 track. NO PROBLEMS. When stuck let off. dig out (belt cools) and away you go. I buy these belts for less than half the price as the 1115. If the 1115 can garantee me more than double the life I would consider. Don't get sucked in.
Washing a belt??? lol. Is that like locating a "Bucket of steam" or getting a "Sky Hook". lol Sorry folks. lol. Put the belt on and beat feat. This is not rocket Science.
srt20
People that know, know that belts are made in a mold. In this mold, they must put mold release compound in to get the belts out of the mold. This compound stays on the belt. You put the belt on your sled and it makes the belt slippery on your clutch sheaves. Now you got crap on your clutch sheaves.
And people are always complaining that their sleds are slow, get bad gas mileage and get beat by their buddies smaller cc sled. Take the time to do things right and bam! you got a good sled.
This is brand new to me.
Falcon20
Been washing new belts since 1980, there's mold release and who knows what else on new. Soap and water does the job. You can lightly wire brush the side of belt also. Same goes for both clutchs. Do not ever spray anything on a clutch or moving clutch parts. Aluminium is porous as are the fiber bushings on arms. More performance is lost than any where else in your clutches and belt.
On a totally different tangent we also wash our dirt tires w/soap and water after a night of racing to get off any track prep solutions that were used. It gets absorbed into the rubber. We've had dirt "stains" that didn't come off bare aluminium. Have also wire brushed (electric) the contact surface of dirt and asphalt tires. Tenths, hundredths and thousandths matter on the clock.
elf
yes, the 1122 is the next step down and then to 1080 is cheaper yet. I currently have the 1080 on my 06 switchback and got over 5000 miles out of it. It's now the spare so I will keep that one as a spare also. The dealer is throwing in an extra 1115 belt for free so I'll use that as my spare for now.
indyxcr
The new Polaris Belts that you are talking about $189.00 I was shocked but the dealer said you should get 2,000 miles or more on a new belt. Dad has 1,355 miles on his still looks like new 2 years old. Don't waste money on a 2nd belt use your old belt you had from your last sled for a backup. This would work if your belt had a problem. It would get you back to your hotel. The dealer told me just don't buy a cheaper belt, it will not hold up in a few days it will fly apart and go through your hood, cheap belts cannot hold the 150 hp sleds. Even the $100 Polaris belt will come apart 2 people tried it, bad damage.
mjkaliszak
You should have made a " spare belt " part of your deal before pulling the " trigger '. I don't wash belts, I don't break belts in ( officially ), I run a 1114, and it has lasted thru some extreme abuse.... ( Jumps - holeshots - being stuck- having studs - ect ) I have about 7200 miles on the sled and still on my 3rd belt , which will easily finish out the year. I rotate belts from new to spare status.
Buy the good belt .
600hoic
Banned
I got over 3000 miles on 1080 belt on my 07 600 IQ and still going!
