These kinda posts usually end up with a bunch of very strong opinions and I don't try to get too involed but I just had to throw my .02 in.
Any of the import pistons (Kimpex, Sport Parts, LLP, Groth Products, and several others) are probably all coming out of the same "Vat" in Taiwan somewhere and several companies put there name on the box.
Most of the import piston failures are because the the skirt breaks off. Not that they won't ever work but the clearance is very critical. If you have even a .001" too much the piston rocks in the bore and the skirt WILL break off. If the skirt gets between the crank and the crankcase bad things can happen. If everything is perfect they will "probably" work. I'll never believe for one minute that you can manufacture a piston, ship it half way around the planet, sell it for half the price of any other piston and maintain the same quality.
This leaves you with two choices, OEM or WISECO. And either is a good choice.
I'm pretty partial to the WISECO products for two reasons, they are a forged piston which makes them stronger and they are less money than the OEM pistons.
One thing to keep in mind is the fact that no matter which piston you choose all of them will melt at about the same temp. So if you have a lean burn down none of the above will be any better than the other.
