As I read his plea (above), the spray is outside, I certainly would not advise him to pressure wash "inside" the house.
he said the inside of the house smells too
Thus, ??smoke can travel into the house to help
IT was a simple solution to the issue at hand
GOD you people must be thinking about a huge fire to burn the house down and to turn the walls black
Haven't any of you ever had a camp fire in your back yard without burning down your homes, or staining your walls??
ever sit by a camp fire and smell your clothes when you went inside??
did you burn them off your back sitting next to the fire, was your face covered in black smoke grease and film?? NO< MAN!
come on folks, get real here,
have to be a moron to build a fire so big as to burn the home down(and yes some morons have done this, a local guy near me burned his house to the ground and across the street was the fire dept
dumping gas onto a running lawn mower ON his deck? , gas went under decck and up she went, total losse even with fire company across the street LOL
so, yes morons are out there)
Smoke isn't a disaster containing black oils and grease that stain everything it touches
way over reacting here
Using smoke has been something cave men used to smoke and cure meats and for other use's
use a little common sense here and smoke can help as a cover scent, if someone wanted to use it!
DIDN't say it was the greatest way, JUST A WAY!
some folks get the wrong idea so fast?? makes me wonder what they do??
baking Soda is a natural odor absorption tool too!
mixing it with peroxide, can also tame smell from a skunk, its used to wash animals (dogs) that get sprayed
I am sure you an mix some up and try washing your porch with it as well!
