plow truck tires
L
lenny
looking for a good set of tires for my plow truck and need advise. So far I have learned a narrow, tall tire is best. I see Mastercraft has a Courser C/T-C that looks real good. I don't want any china made stuff, maybe these Mastercraft tires are made in China,,,not sure. Any help here people?????
m8man
Moderator
agreed. just go with a snow tire. If your just gonna plow with the truck buy a good set keep em on yr round and get many years out of them. I actually run snow tires on my wifes Suburban year round. Now that's kind of dumb I know but I feel better about it and tend to buy tires more ( I wonder why ).
All major manufacturers have a good tire but you may find a deal on one type. If it's only a plow truck stayin close to home I'd also check
www.up.net and look at their sales or classifieds tab. You may just find a set there.
good luck Lenny
m8man
C/T 's are a good snowplow tire for the money, and Good on soft ground too. I used them on the last truck I had.
You're also right with the taller/narrower. The tire needs to cut through the snow to the pavement, not float on top.
Team Elkhorn
Ive been plowing snow for 30 long, long years. :( We have about 20+ plow trucks where I work, F250s, 350s, 450s and 550s, all 4 wheel drive, but we use them year round. We order them with the more aggressive all season tire, whatever brand/model tire the manufacturer is offering at the time. The 4 wheel drives rarely get stuck, unless a noob is plowing with it and does something stupid. (Trying to back over a 4' high snow pile).:mad: Id also recommend using the correct tire size recommended by the manufacturer for your truck. Your already putting undue stress on the vehicle by plowing with it so you don't need to add to it by putting the wrong size tires on it, jmo. Anyway, 95% of the time your tires are riding on a freshly plowed surface, (If your doing it right).:) Also if you haven't plowed before, bring extra plow parts with you, pins, springs, hoses, hydraulic fluid, spare plow motor, etc, and tools so you can fix it out in the cold. Don't forget jumper cables for when you draw down your battery and stall the engine. Oh, and a shovel in case you do get stuck. Have fun! :D
700classic
Lenny, Mastercraft's website shows a dealer in Hancock.
R Crew The Tire Shop
811 ETHEL STREET
HANCOCK, MI 49930
(906)482-1850
joks79
Make sure whatever you get is E-rated.
A E rated tire is not necessarily needed for plowing. I just took off a D rated tire from my F250. The tire was rated at 3195 @ 50 psi. The tires i just put on are a E rated tire and it is rated at 3195 @ 80 psi.
My buddys dad just went thru a pair of firestone destinations on his 98 chev 3/4 ton in 35k miles that were d rated
radsrh
The rating on the tire on has to do with how much weight the tire can support, I have run both E and D rated tires on my truck. With the D rated tire the towing capacity of the truck was lowered because they where not made to handle the additional weight of a loaded trailer. How many miles you can get on set of tires has many factors including proper inflation, rotating the tires, proper alignment of the truck, the compound of the tire (hard or soft) and driving habits.
L
lenny
I bought some Firestone destination for my Excursion. I selected those particular tires because I was told they would smooth out the ride on the stiff sus of the X. The tires did soften the ride and was very pleased with it but my gas mileage went down 2 mpgs. No lie, I check nearly every tank and as soon as I added those tires I lost 2 mpg immediately. My wife also gashed the side doing through the carwash and the tire was destroyed. The Firestone Des are a soft tire and probably good for many applications but not an Excursion because it is a very heavy rig. LT tires from now on every time for trucks for me!
azandy
I used firestone transforce AT tires on all our trucks when I had our plowing business.
They had great traction and were not too much cost.
We never had any trouble with them.
Some trucks we would get two years out of them, but most our trucks got one season and the following summer.
We used these trucks in summer for lawn care and landscape.
Jmho.
L
lenny
now thats what the truck would need for hauling but probably would not have softened up the ride
radsrh
Indy Here is a chart of a tires Load range or ply rating. As you can see a D would be a 8 ply tire, and a E would be a 10 ply tire. The number of ply's effects how much weight a tire can support. The load of a tire is determined by the manufacture and it's not always true but in general a tire with more plys can handle a heaver load. My truck (2500HD) came with a E rated tire and a towing capacity 10100 lbs When I changed to a D rated tire it was not able to handle the same load as an E rated tire and lowered the towing capacity of the truck. Now I am back to a E rated tire and the towing capacity is back to 10100 lbs.
A truck's towing capacity is determined by a formula which takes into consideration a number of variables. Including, but not limited to, chassis structure (frame strength, wheel base, track, suspension, wheels, tires etc.), engine, transmission, brakes, axle strength, axle ratio and so on. The reasons behind these maximum ratings are to avoid excessive stress on the vehicle in question, and SAFETY
That is why on heavy duty trucks that a made for hauling heavy trailers, and on semi's they run dual back tires. Two tires can handle a heaver load then a single tire.
So the rating of a tire has nothing to do with the tread or how long a tire will last before the tread wears out, the tread is the outer most layer of the tire.
Load rangeThe Load Range Letter on light truck tires indicates their ply rating.[7]
Load Range Ply Rating
A 2
B 4
C 6
D 8
E 10
F 12
G 14
H 16
J 18
L 20
M 22
N 24
There is a common misconception that there is a specific equivalence between a tire's Load Range (or ply rating) and its inflation pressure at which it achieves its maximum load.[8] In reality, tires of the same Load Index may require dramatically different pressures to achieve their published load ratings.
This can be seen by consulting the standards published every year by the industry standards group, the Tire and Rim Association. As an example, their 2010 Year Book shows that Load Range C tires may require 35 psi (240 kPa) or 55 psi (380 kPa), Load Range D tires may require 50 psi (340 kPa) or 65 psi (450 kPa), and Load Range E tires may require 65 psi (450 kPa) or 80 psi (550 kPa) to achieve their Load Index and Maximum Loads.[9] This is also the case in the tables published by major tire makers, who do follow these TRA standards and have multiple inflation pressures for the same Load Range in the tires they sell. [10]
It is essential to consult the guides like those just mentioned when making tire substitutions, and to read exactly what is imprinted on the sidewalls of tires. A different size of tire with the same Load Range may require a higher inflation pressure, and may fail in use if under-inflated.
