Polaris exaust valves
jayz
Does anyone know when putting the exaust valves back into the engine does the curved taper part of the valve face up or down in the engine?
Kdedecker
I am pertty sure if you look at the valve it will only truely go in one way. The shaft on mine had an off set and would only seat one direction. I could be wrong, but look at it and let us know.
On doo's (01 doo 700) the powervalve isnt' curved, it's completly flat and says the letters "top" on the top side which imo is a good idea.
penaltyvectors
I asked this question when I was rebuilding my top end and got various responses. The one guy in this post got it right. There is ony one way to put these in otherwise you will not be able to tighten the bolts without a gap.
Also if you have an older sled (mine was a 2004 switchback) that still has the cast aluminum blades do yourself a favor and spend the 70 a piece for the stainless steel ones so you don't have one break off and go into the piston like mine and others have done. I sure wish I had it would've saved me a grand in repairs.
snow_monkey
x,2
D.B. Cooper
Polaris dealer. The replacement valves are stainless steel.
The STAINLESS VALVES are POLARIS only (POLARIS part # 2202838 - order two kits) and are sold as 1 kit per cylinder including 1 stainless valve, 1 new bellow (ORANGE are the latest and greatest) + 1 new spring + gasket.
They're not cheap, approx $160+ for the pair, maybe more????
The STAINLESS VALVES are available for the 800 (2002-2005) Big Block only
Check to make sure that the gasket/exhaust pin-hole lines up with the gasket, I've heard of some that don't.
As posted above, they ONLY install ONE way, unless you're using a sledge hammer to drive 'em in, you can't screw up.
D.B. Cooper
that's odd, a buddy with an 02 x edge 600 said he put his in backwards and blew it up
Not unless he literally FORCED them in with a large hammer, lol
The valve/guillotine is built/designed off center, period.
Your bud may have blown up his sled, however it certainly was NOT from installing the exhaust valves "backwards"
As long as you can install and fully collapse the spring tension by hand to where the valve body meets the cylinder, NOT having to use the bolts to draw them together
Noway can you put in backwards. 02 edges had aluminum blades. They would break and or melt. That is why I changed my 02 800 xcsp and my 03 700 RMK over. I purely lucked out and caught the blade at the edge of breaking. They would break on the nut end and melt on the guilitine end. Poo figured it out half way into 03. This was the start of a whole long list of Poo blunders at that time along with semi sealed drive bearings ands voltage regulator problems.
probably was the case, smashed them in with a hammer lol
Note: 2600 miles on current Poo. Went to clean valves and they looked great. Some normal amber/carmel color with no build up. First time I had valves off to clean. (They were working just fine). Thank you Amsoil Interceptor. Stuck them right back in. No black gunk or plugged holes like I used to get on my switchback with POO VES oil.
D.B. Cooper
Note: 2600 miles on ccurrent Poo. When't to clean valves and they look great. Some normal amber/carmel color with no build up. First time I had valves off to clean. (They were working just fine). Thank you Amsoil Interceptor. Stuck them right back in. No black gunk or plugged holes like I used to get on my switchback with POO VES oil.
I HAD both a 2001 EDGE-X 600 and a 2002 EDGE-X 800 at the same time.
SAME POLARIS oil in both sleds.
At the end of the season the 600 valves were clean, the 800 were ALL GUMMED UP.
Valve cleanliness is the result of several factors, not just oil type.
Believe what you want on AMSOIL, I'd never run it again.
I don't want to start a oil-brand bashing thread, but a well respected engine builder/machine shop in Northern Wisc will tell you that he can identify AMSOIL users by the fact that all the crank journals are "blued" due to heat.
'Nuff said.
'Nuff said.
But the stickers look so cool!
'Nuff said.
and thats anothers opinion. I will stick to what works for me. thank you.
fatdaddy
Just blew a bellows on my 03 700 xcsp, pull them out after 3000 miles and full of crap, cleaned them and put them back in, they had the numbers facing up on the blade, and the larger tapered end was up. does this help.
mn_polaris_guy
X3, only goes in one way, valve body must sit flush to engine, 'blade' is off-centered, only goes in one way.
I just replaced one 'blade' and will be replacing the other this offseason. One started to warp and the other is starting too. Not a cheap fix (at least not as affordable as I was hoping) :p
