polaris grease fittings
mustsled2
hey guy's, I need some help. I'm trying to find the grease fitting for the jackshaft bearing on my 09 shift 600 136". The manual says nothing. Same question on my wife's 09 shift 550 fan. Any help would be greatly appreciated. Thanks,keith.
Probably don't have one. You can add one, take the triangular metal housing off, drill the hole needed for the threads of a grease fitting and tap it out, good to go.
xcsp
Won't do much good as there is a sealed bearing used. Item #3 in attached picture.
Remove the secondary clutch, and that triangular housing to get to the bearing.
You can carefully remove the seal on the bearing to gain access to clean and re-pack the bearing.
True, but the standard driveshaft/jackshaft bearing with a grease zerk is "sealed" also.
xcsp
Never had the flange off of the drive shaft (below the jackshaft) on my Polaris sleds as there is a grease fitting for that one so can't say for sure on that specific bearing, but how would you ever get grease to enter into a sealed bearing when the seals are in place?
there's a tiny hole in the bearing. When replacing the bearing, you have to line the hole up with the grease zerk.
xcsp
Maybe on your sled, but my late model (IQ's) don't and by just adding a zerk to that flange isn't going to do any good. Only hole in the bearing on my sled(s) is the one that the shaft goes through.
it's a teeny teeny hole. Yours probably doesn't have one.
rp7x
missing zerk
if your just looking for it now forget about it you should have greased it in the spring to push the water out grease it every ride it will never go bad
xcsp
mine has a zerk
Are you sure you have one on the jackshaft flange behind the driven clutch?
Don't see one shown on a parts page for your '07, we are talking about the jackshaft, not the driveshaft, which is below the secondray (driven) clutch.
Yes, definately grease that zerk/fitting on the drive shaft at the end of the riding season, not so sure if I'd do it every ride unless your putting on 500 miles a trip.
D.B. Cooper
Keith,
I have a 2007 D7, no zerk,
Here's what I did:
1) Obtain a triangular flange with grease zerk from an older POLARIS
2) Obtain a bearing with the pin-hole in the outer race, (sold by POLARIS and "ALL BALLS")
Keith,
Here's what I did:
you could just drill out and tap some threads and slap a grease fitting on the existing triangular flange
snodogg
There isnt one (zerk) my 09 doesnt have one either. manufactured with sealed bearing instead, just go riding.
