Polaris IQ/Fusion 600 - Tool required to reach lowest bolts on exhaust manifold
Anyone know what tool can be used to reach the lowest bolts on the exhaust manifold on a Polaris Fusion 600? Mine are leaking just a little, and I'm assuming the bolts got loose. Not sure how to get at them with regular tools, but I figured someone on here knew a shortcut. Maybe I need to replace the gasket while I'm at it.
Polarice
Can't you use a short stubby Allen wrench and a small wrench for leverage? That's what I had to do on the iq 600.
I forgot to mention mine had the ball on the end to get the angle better.
By ball on the end, do you mean similar to the tool that vic_junior linked? That looked like it might work well. I assumed there had to be a way to get at those bolts without loosening up the engine!
Is there a gasket in there that goes bad that I should change at the same time I am messing with these bolts?
Polarice
Yes, the ball end that was on the previous link. Now that I recall, I used a regular sized Allen wrench with the ball at the end and used a wrench on the short end for leverage. You could use a small pipe too...I just don't have one. It looked like that tool posted would work easier than what I did but who wants to buy more tools!
There are gaskets. I put new ones on and used rtv to seal it. You could probably just rtv the old gaskets. I had the same issue with my 07 which is why I sealed mine.
Extra long allen sockets just like vic junior said, got mine at harbor freight work great for this, probably like $10?
Polarice
On mine there were one or two bolts that I couldn't get to without the ball. You better purchase those Indy if you're going to be a machinist!
Yup I didn't get the ball end but the ball end would probably be better for this purpose. mine are metric so I would assume yours are too.
Metric on the Liberty motor? What's this world coming to? LOL. Thanks, that would be good to know before I buy the tools. I'll probably just go to Sears since it's close by.
