Polaris secondary disassembly
I'm looking in my manual and none of the clutches look like this one with 3 screws on the helix (i took the 3 screws out already, they're hex screws). I took off the snap-ring and nothing is coming apart. Is this a sign it's bad? I plan on disassembling it to clean it, put a new spring in, and put 3 new buttons in. The helix doesn't want to budge. It looks almost as if it's a different helix since none of the other ones look like this. And, on the parts finder it says there's a washer under the snap-ring and there was none.
Also, when left untouched, i measured the outer edges of the sheaves with my caliper and they're 1.994" apart. When i turn the moveable sheave, they're 2.024" apart. Shouldn't they spread more than that or not?
doomsman
the screws adjust the deflection
Get some one to help hold the helix and tap on the shaft with a block of woodI use a socket but you can damage things as well as the socket
it was a fad a while back to remove and some even milled for more over drive
just twisting it some won't push it full open
Turns out I do have a clutch kit. I took the primary to Ray's cycle to get rebuilt, and the weights are heavier then stock. Either 62 or 64 grams instead of 60 i'm assuming. I ended up taking the secondary there, mostly because the helix won't line back up anyways.
