skidoodoug
Went out and started my daughters 98 Formula 500. Primed it up and started fine. Started to die. Primer again. Idled nice. More RPMs not bad until approx 6000 and then sounded like it was starving for fuel. Again get it up to 6000 starvin for fuel. Primer again, takes off gets to about 6000 and bogs down. I am able to "pump" throttle and it takes off to 8000 but when I back off and nail it again, bogs down. By this time there is a puddle of fuel under the front of it. Wasn't leakin when it was off. I am certain it is not leaking from the carbs them selfs. It appears to me that it is leaking from either an outlet hose at the pump or the pump itself. It only leaks when running as I cleaned it up in between runnings.
I have never had a fuel pump leak, but I assume they can. I am more leaning toward a small crack in the carb supply hose. Would a leak cause the starvation issue? Had both carbs off, looks pretty straight forward to change out everything. Any thoughts.
Thanks
Thanks
