Loose is fast!
Loose is best... less wear & tear on everything. Just tight enough so it doesn't rachet on the drivers. IMO ... of course.
X2 I bet the track on my 600RMK sags 3-4" with no weight on it.
I am actually a firm believer of a loose track. On my IQ I would run it as loose as I could before the track would slip on the drivers. I also run 144 down the center. Well I have found the error in this, my front track shock bottom eye is worn down to almost nothing.
If you gonna run it loose with studs, I suggest keeping a watch on that front track shock.
Do you think it was run loose for speed.
http://www.youtube.com/watch?v=gu1VU5-gr9o
