So, I'm keep looking at these Indy 600's. I have a couple questions about the current 600:
1. Oil usage - seems like they run lean. Can you turn up the oil pump on these? Should you? What's the right ratio if you want the engine to last? I understand they are set up for the EPA.
2. Fuel filters/EFI system - I understand they operate with some kind of high pressure EFI system for which if the fuel filter gets clogged at all, you risk a burndown. How often do you need to replace these filters? How much does it cost - is there an economical substitute? I seem to remember reading they are like $60/each and have to be changed every 1500 miles or so.
