HCR is an oxygenated fuel. Due to that alone, I would shy away from it. Non oxygenated race fuel wont hurt anything, other than pipe temp sensors, and air fuel gauges probes.
Why do you want to run that fuel in a stock motor? Awfuly expensive fuel if the additional octane is not required....
If your just looking for the race fuel smell, just mix a gallon per tank and you should be good to go.
