Polaris supplies a pump with the sled to add air to shock or let it out. It appears the gauge on the pump is not even close to correct pressure in shock. A couple of times now I have added air and come to find out there is none in the shock. Also discovered it takes several pumps just to get 10 psi in the shock. I ended up using a digital pressure gauge to verify amount of pressure I do have in the shock. Has anybody else seen the same issue?
Thanks
Thanks
